I haven't used DroneDeploy in a while, but I was given a project this past weekend. As I was setting up my flights I noticed a new tab on the left side when your in the "Fly" section, labeled "Airspace & LANNC" for LANNC enable areas there will be a green dot and if not it will be red. If you click on the tab it will pull up an airspace map of the area that you have mapped out and show you all of the airspace info including TFR's. I was very impressed with the level of detail of the information provided.
