This may be clear as day to some of you, but I can't figure it out.
Area in question is the Class E airspace associated with POU, a Class D airport. Here Airmap shows that authorization is required for where the X is in POU E4 airspace. The sectional shows the Class E extension as depicted in Airmap.
And here is the same area from the FAA Facility Map
Now on the FAA site there is this:
"UAS Facility Maps show the maximum altitudes around airports where the FAA may authorize part 107 UAS operations without additional safety analysis. The maps should be used to inform requests for part 107 airspace authorizations and waivers in controlled airspace." So I'm not assuming that just because there is no grid over the Class E Surface extension of POU that Airmap is wrong.
It seems illogical to me that the Class E extension would not be included in the FAA facility map.It has in prior versions of the map. I've also read that Class E extensions of Class D airports' airspace doesn't require authorization, but I haven't seen this on the FAA's website and Airmap doesn't concur.
The conclusion I'm drawing from this is that the Class E extension won't be included in LAANC when it launches in the North East on 8/16/2018. I can't understand why, especially given that the Class D airspace likely will be included.
Has anyone had experience with LAANC and Class E surface extensions to a Class D airport?
