Litchi Orbit - georeferenced point
PaulMartin
Hi all. I’m lookjng to utilise orbit over known gps coordinations within open pasture. I don’t have any visible landmarks to manually set up over. I noticed there are no input coordinate options within the orbit function like waypoints have. Would I be best to mark up a kml? I tried this with points but it converts them automatically to a waypoint route within Litchi which is not what I want. Any suggestions appreciated.
I don't know of a way to set up a perfect orbit in Mission Hub. I would use Google Earth to first draw a circle with the desired radius using the measure icon in the tool bar. You can then save this object and export it from Google Earth as a kml. It will import into Mission Hub. Put a POI in the center of it and your done. You can tweak things easily in Mission Hub if needed.
Agcopter
