Advantages and disadvantages of 12 μm UAV thermal Imaging Movement
linkli
12 μm is stronger than 17 μm, there's no doubt about it.In March 2018, at the IWA2018 exhibition in Nuremberg, Germany, I saw the IRay’s 12 μm 640, 384 detector. After a year of contact with IRay, I successfully tried the latest 12 μm outdoor thermal monocular in the previous period. That’s really a super product , as far as I know there are some advantages with a 12μm detector for thermal monocular comparing to 17μm .
I did some tests with monocular with 12 μm detector plus a 25mm lens and the other one17μm detector plus a 35mm lens which is amazing,the observe distance is the same! And when they both use the 25mm lens, the observe distance of 17um detector is over 30% more than the 17 μm detector .
The material used for the 12 μm detector is VOx which has significant advantages than a-Si. NETD is less than 40mK, 14-bit digital output is supported.High sensitivity and easy to use,it keeps the primary competitive advantages of IRay products. Currently IRay 12 micron 1280×1024, 640×512, 384×288, and 256×192 full range detectors have been in mass production. The following is a specific description of the 12-micron detectors.
Resolution 1280×1024,12 μm
Features
1. Super large FPA ,XGA high resolution detector;
2. Frame rate up to 60Hz ;
3. Typical power consumption is less than 350mW;
4. NETD < 40mK (@f/1.0, 30Hz, 300K);
5.14-bit digital output.
6. Supporting detector Evaluation Kit (can be customized)
Resolution 640×512/384×288
Features
1. Available with ceramic or wafer level (WLP) packages;
2. 14-bit digital output;
3. Frame rate up to 60Hz
4. Under typical working conditions, the power consumption of 640 and 384 array products is less than 150mW and 100mW respectively;
5. NETD≤40mK (@f/1.0, 50Hz, 300K);
6. Support for TEC-less and shutter-less applications.
7. Supporting detector Evaluation Kit (can be customized)
Resolution 256×192
Features
1. 14-bit digital output;
2. Wafer level packaging (WLP);
3. Provide a standard I2C interface;
4. Support 5V/1.8V standard voltage and support MCU-based application solutions;
5. Under typical operating conditions, the power consumption is less than 60mW.
So products with 12μm detectors have advantages in size,weight,power consumption etc.
I heard that IRay will bring more 12 μm products to Laser-world of Photonics 2019 exhibition in München,Germany. If you have more information about them, please leave a message.1439
‘Same visual distance’
IRay is the only manufacturer in China that can supply high-performance 12μm pixel size series detectors in batches.
I have bought a thermal imager of IRay. It performed very well and is very cost-effective.
Safety3rd
