Do you do any post-processing for broadcast?
Perch
Albuquerque, NM
I am flying a DJI P4A and finding that it seems to have a little too much detail in the video. I have started transcoding the files to ProRes. But I still get a strange look to the video when broadcast. It's like there is too much detail in the shot causing some strange vibrating within the video - especially in video with a lot of detail, like trees/leaves. Looks fine on edit, but not when it gets to broadcast. Shooting 4k h264 progressive. Editing 1080p. Exporting ProRes out of PPro CC 2020/2019. All my other 4k cameras I can bump up the detail a little in Lumetri and not have this issue at all, even with a DJI OSMO. I've looked for a details setting for the Phantom, but cannot find one. Anyone else see this at all or do any processing before post - or have any tips for the drone video?
Thanks!
I don't have any broadcast experience, so I'm not sure I can be of much help... However, here are some thoughts you can check on if you haven't already:
  • are you using ND filters to ensure you are following the 180 degree rule and setting your shutter speed to twice your frame rate?
  • are you shooting in the same frame rate with the drone as you are using for your broadcast?
  • have you played with the style settings in the camera to see if adjusting the sharpness, contrast, or saturation would resolve what you are seeing?
Thanks for the reply. No ND filters on the camera. I shoot 29.97 for broadcast. Frame rate typically doesn't affect the image like that - possibly speed changes could, but I don't see that happen anywhere else either.
I'll check the style settings. I didn't see the sharpness in there. But I'll check again. That was my first thought before.
Thanks!
TC
Barry woodham
