Mapping is my next area of interest
Tim Jones
Frisco Texas
But honestly not sure what the best course of action would be to get started.
I fly primarily Pixhawk based craft, which have very solid survey software for capturing the images.
I have even managed to get some survey missions flown and ended up with that big folder with photos, so the capture part is no issue.
When looking at the post software options you find these incredibly expensive services.
Are those so expensive because of the processing power to stich the photos?
What do the successful mapper/surveyors use to delivery their content after the capture process?
I found an opensource one, but would not paying for the right software if the cost vs results factor is good
Here's an article that you might find worthwhile: Who Should Process Your Drone Data?
Of course, they're trying to sell a service, so you can guess what the answer is going to be, but it covers some of the options and the pros/cons of each. We process everything in-house and have Pix4D, PhotoScan, and (most recently) Context Capture. These programs cost thousands of dollars, so you probably want to demo everything for a while before you invest. The online services don't really compare to the control you have over your project using desktop software, but cloud services are cheap.
After you process a lot of data, you'll learn that there are things that you can do better in the field to collect better images to make better models, so you're always improving. A successful aerial surveyor will then validate their data through the use of check shots. If someone offers me a "professional" UAV survey without some form of accuracy statement and how they measured it, then it's not worth a dime, it's just a pretty picture.
So, get a couple of software trials and learn how to process your data. If you're serious about aerial mapping beyond that, team up with a land surveyor and add some control to your next project. Then comes the hard part... finding someone that's willing to pay you for your time!
Great information, I will look into some of these. Truly going to be a go to site. We certainly seem to be getting the correct people gathered
As Uav_mapper stated, the online services are not nearly as good as being able to process in house and have control over your data. If your just getting started they might help with getting your feet wet but if you are serious about learning how the process actually works then an in house solution is your only option. Photoscan has a big learning curve but is worth it in the end, pix4d also has a desktop version that is a little more user friendly but in my opinion photoscan came out on top so I went with it. If you don't have a very capable workstation to run the program on you'll need to consider that cost as well since either program is VERY CPU, RAM and GPU intensive. I ended up building a custom workstation since my CAD workstation didn't cut it. Photoscan offers a 30 day trial and I think pix4d does something similar(at least they did when I got into this) so start with one, work with it for the month and then try the next to see which you prefer.
I know you stated that you already captured some data sets but one thing to think about is the quality of the images you have, are any over/under exposed, what time of day did you collect the images, are there lots of shadows, did you achieve sufficient overlap, did you maintain a constant elevation AGL during the flight? Lots of the flight planning apps are customizable and that could be a good or bad thing...drone deploys app will let you set overlap down way under the recommended minimum overlap for photogrammetry (60side/80front) they also give you the option of "automatic camera settings" which can really cause a disaster of inconsistent imagery. Most apps dont even offer the ability to follow the terrain and achieve a constant AGL but if you have terrain with a large elevation change from one ond to the other you GSD could be what you want at one end and way over on the other... or on the other hand it could be the opposite that you have a smaller GSD and insufficient overlap at the other end depending on if you launch from the high or low end of the project. There are a lot factors to consider when collecting imagery and in the end if you don't think it all through you will have inconsistent results, especially when trying to achieve an accurate 3d model and not just a nice looking orthomosaic. GCP placement is another factor once you get there that depends largely on what type of terrain you're mapping. The best imagery will be from around mid day on an overcast day so there is even soft lighting and no harsh shadows.
As previously stated once you get past all that the next thing is to find a surveyor or some other way to get GCPs into your data, until you have control there is no way to check the accuracy of what you're producing. Teaming up with a surveyor would be the best option and probably the hardest unless you know one (or are one like me) but it could be done if you can prove to them that it would help them. Other options are Aeropoints(at 6
$6k for a set), or buying and learning how to operate your own RTK set up which is also a pretty hefty learning curve.
RTK is getting cheaper. You can Hear+ for around 600 bucks now.
Thought there is still the survey time to set up.
My work station is pretty robust as it is used for 4K video editing and 3D modeling.
Tanks for your information
We use both Pix4D Desktop and AgiSoft PhotoScan Pro; as others have said you can't beat them for quality of product, but the price of either one is pretty steep. Nice thing about Pix4D is you can pay for it monthly (still not cheap).
I've also used PrecisionMapper. Processing is online so a bit more limited, but I've still got some really good results too.
PrecisionMapper | Drone & UAV Mapping Analytics
Cheers,
Troy Zimmer
Reactions: Outta Control
Sameeksha Bhadwaj
