Need Help w/ Drone Selection
bldrones
I'm new to drones and want to create a DIY build for fun. Will the parts below work well together? Is there anything I'm missing? Is there any way to get everything below ~$400? If necessary, I'm fine with using my phone as a display instead of the goggles. Also is GetFPV expensive? Is buying from Banggood cheaper? What about hobbyking? Is there an easy way to attach a GoPro Hero 8 for cinematic shots?
Frame: Flywoo Mr.Croc 5" 225mm Freestyle Frame Kit - Gold
Motors: EMAX ECO II Series 2306 Motor (1700KV/1900KV/2400KV)
Lipo: XILO 1500mAh 4S 100c Basher LiPo Battery XT60
Stack: MAMBA MK4 F722 APP 45A/F55A/F65A_128K 3-6S Flight Controller Stack 30mm/M3
GPS: Mamba GPS/Beidou M8PLUS/M22
Charger: iSDT 608AC Smart Battery Charger AC 50W DC 200W 8A w/ Detachable Power Supply
FPV Cam: Foxeer T-Rex Micro 1500TVL 1.7mm FPV Camera
Transmitter: RushFPV RUSH TANK II 5.8GHz VTX w/ Smart Audio
Props: https://www.amazon.com/12pcs-HQProp-Tri-Blade-Propeller-Quadcopter/dp/B07XGHYKLB/
Antennas: https://www.amazon.com/SoloGood-RUSHCHERRY-Antenna-5-8GHz-2-5dBi/dp/B07K87P3XM?
Controller: BETAFPV LiteRadio 2 SE Radio Transmitter - FrSky / ELRS
Goggles: EV800D 5.8GHz 40CH Diversity FPV Goggles w/ DVRv
Probably not the best place to ask those questions. You should go to an FPV form.
The vast majority of our members are not "Custom/DIY" type and pretty much by Ready-To-Fly systems here. We are more about getting the right tool for the job for the best price without becoming a drone build GuRu.
Argosyhoosy
