Daylight Waiver Question about Geography
AcesFull
San Joaquin County, California
I want to apply for a Daylight Waiver to market some ideas I have in my home town. I'm Gold Seal alumni so I believe I have the knowledge to complete the application and comply with the terms of the waiver. My question is, and I've searched high and low is about specific geographical location. Will I need to specify 'where' I want this waiver? Or does it apply anywhere in the US when I'm complying with all other regs? Do I need one for my city, the city next to me, and all cities I want to market my ideas or just one general 'Daylight Waiver'?
Thanks. I love this forum and hope to someday become a productive contributor.
I wrote Class G airspace on my authorization request. Figured if I get into controlled airspace I would then try to use LAANC approval number for class G. Not sure if Class G approval will also work if I need to get authorized through LAANC. Let us know what you find out. Thanks.
Regards,
JD
Reactions: AcesFull
The waiver should grant you authorization for any class Gulf airspace.
Reactions: AcesFull
Regards,
JD
As Luis stated, the 107.29 "Daylight Waiver" will be for Class G airspace. After you have the 107.29, if you want authorization for night ops in controlled airspace you'll have to submit a separate 107.41 application for an "Authorization with Waiver Attached" for each Class B, C, D, or E controlled airspace you wish to operate in. The LAANC system can only be used for operations during daylight hours.
Roy thellmann
