High resolution cameras for crop mapping
Pawel
Hi,
Is anyone here using 60 plus MP camera/s for mapping crops? Things like plant counting, tassel/ear counting and phenotyping require mm resolution and standard 20 MP though capable of doing these jobs fail when it comes to efficacy and efficiency. This is at least how I see things based on my experience.
Thus my question.
There are a few 60-61 MP cameras available these days. What camera do you use and how it does.
One of them is Sony ILX-LR1. Curious to hear from those who uses it. What lens for mapping?
What drone do you use and what is your setup?
Anything
Best,
Pawel
IMHO as a business, the cost of the sensor vs how much work is available for a sensor like that is prohibitive. We fly thousands of acres per season and I wouldn’t purchase one. It’s great for special purpose and research. Also not many platforms available to process the resolution needed for that data. You would have to be a specialist.
I hope this is helpful.
Thanks for your valuable comment.
I indeed look at research and agree it would have limited use in general mapping.
Looks like you are busy flying. What kind of jobs do you do if I may ask?
No need for that gsd. Unless you need it for object detection.
yes research is where I find it might be useful.
other than that, I was flying and counting lettuce app. 2 weeks after planting on 20 ha last year. Required resolution was at around 0.6 cm/px. Used M3M and field edges were bit difficult due to high trees here and there taller than altitude I was flying at. Being able to do this from a higher altitude would help.
Jlang0
