- Joined
- Feb 22, 2019
- Messages
- 229
- Reaction score
- 148
- Age
- 55
+5F is officially too cold for a DJI phantom 4.
My previous best was flying at +19-20F. We did a 3 battery mission and it all worked out ok (prior to our DD / ipad issues.)
Yesterday the forecast was for +17F, but according to our vehicle the temps never got above +5F in our specific area. We must have found a cold pocket of air or something.
I could be completely wrong about everything, but here's what I think happened.
We were attempting a multi-battery survey mission, flying with pix4d capture on our ipad. I had tested this all out on Monday in +30F temps, and everything worked perfectly.
Our first flight was perfect. I set the mission up to work from far to near, so the first flight was the most challenging in terms of distance, but it sailed through that fine. Partway through the 2nd flight the drone just stopped and hovered in place. The hand controller/app was receiving data back, but it appears that the drone couldn't hear [all of] the messages the hand controller was sending. We still had a positive link apparently and the come home button worked immediately. We reset the mission and sent it out again, but after one leg of the route it stopped and hovered in place again. We repeated this about 10 times, with the range/results getting less and less. Finally we couldn't even get 100' outbound to resume the route before the drone stopped and hovered in place.
Also, on the landing attempts, as the drone got colder it had more trouble finding it's landing spot. It would hover above and move around, reset it's orientation, and do that about 5 times before it finally would descend and land. On the final flight it didn't seem to want to come down at all, so I just pulled the stick down and forced it to decend ... however, it stopped at about 6' AGL and wouldn't descend any further. Also, it was pretty far from it's landing spot, so I attempted to steer it over closer to me. I discovered that my control inputs only worked one direction and that was full speed. I couldn't fly side to side or the opposite direction, and I couldn't nudge it slowly. Now I'm 6' above the ground and can't land and my attempts to nudge it have just pushed further away, now dangerously close to being under a tree overhang. When I let the stick up it wanted to climb back up to altitude. I still had clear sky above me so I gave up trying to force the landing and let the drone resume whatever it was going to do. My mission altitude was 150' AGL, but now the drone climbed to 320' and resumed it's attempts to land. Thankfully I had plenty of battery at this point and the system eventually found itself and landed safely.
My theory is that the cold actually affected our hand controller first and more severely than the drone itself. Somehow this degraded our transmission power, so at some level, the drone was not hearing our ground control messages and just stopped. But I could never reestablish the mission/route in flight. The only thing I could do was return, land, reset the mission there, and it would take off and resume again.
But then after being out for an hour, I think the cold was beginning to adversely affect the phantom 4 itself and somehow caused issues with finding it's landing spot. We kept our batteries warm so flight times were fine, but the cold seemed to get us in other area.
Hopefully we don't have any more of this crazy cold weather until next winter now ... but lessons learned?
1. The coldest I've flown a successful multi-battery mission is around +20F.
2. Keep your hand controller warm if you can, it seems like the cold might affect that first and more severely than the drone itself.
3. If we have to go out in this sort of weather again, we might try bringing the drone and hand controller into the car between flights and just blast the heat for 10-15 minutes before sending it off with the next battery.
4. The cold does take some time to soak in, so you might be able to sneak off one successful flight, even if the temps are way below recommended.
5. Store your fresh batteries in your arm pits to keep them warm.
Anyone else have any arctic tips for when it's way too cold, but you still have to be out there doing work?
Thanks,
Curt.
Thanks,
Curt.
