Looking for a high nit phone or tablet, any suggestions? good battery life as well?
I just can't see the value in the Tripltek tablet. At 800 dollars I could buy three very good tablets. I carry two tablets with me on every job. Used with a sun shade I have no problem seeing the display as long as I position myself so I'm not getting direct sunlight on the tablet, and that has always been fairly easy to do.
I purchased a 10 inch Samsung 128k tablet and the Devaso sun shade and have tested it on both of my drones and works very well. For the price difference I can deal with the sunlight issues.
The only issue I've had with the TRIPLTEK Pro is the M2 remote charges the tablet. I can only fly one battery before the remote's battery is depleted.
TRIPLTEK is supposed to be making a cable to fix this. In the meantime , I'll use my iPad Mini 4.
I use a Lenovo tablet that has what they call battery protection mode. The tablet won't charge until the battery is below 60%. When I fly Inpires it's not an issue- I guess the Inspire remote battery can handle the extra amperage draw, but I always make sure the tablet is in that mode when I fly the Mavic 2 Pro otherwise I have the same problem you describe.
Lenovo Tab M10 FHD Plus - runs DJI Go for my Inspires, DJI Go4 for my Mavic 2 Pro, also Litchi and Drone Deploy. Perfect size, nice bright screen. I'm in S FL and occasionally use a sunshade but often don't need it. Also doesn't shut down in the head like an iPad does. Generally available around $150. You can spend hundreds more, but you really don't gain much.
Just want to share my experience with Tripltek 7Pro tablet. It is presented as "protected against the elements" and "water-resistant" (expecting a rating of IPX4) and for which I was ready to pay more.
Great screen visibility in full sunlight, but first time it got under a light drizzle 7 months after purchase... the power button stopped working due to water infiltration. Tripltek does not want to repair the tablet under warranty.
So why pay more? Although I prefer to support local companies I will replace it with a Ch... tablet 1000 NITS at half the cost, and if I get 4 months use out of it I am a winner!
Great screen visibility in full sunlight, but first time it got under a light drizzle 7 months after purchase... the power button stopped working due to water infiltration digital notepad. Tripltek does not want to repair the tablet under warranty.
Can someone recommend me some cheap tablets with long battery life? My budget is maximum US$100 or slightly more.
Tell me roughly what is the battery life for the recommended tablet...
for streaming videos alone?
for reading ebooks alone?
for general purpose?
And what price and where can I buy it. Thanks.
I guess it depends on what you are doing and wanting to load as not all apps only support a select set of devices, but I have had very good luck with one of THESE Oukitel. Huge battery, rugged and good brightness for outdoors use. There are ones with even bigger batteries. Even without service I just use my hotspot or phone hotspot which one or the other is always on when working.
Triple Tech is a great unit for storage and brightness. The biggest problem I have is the battery life. I suppose you can’t have a bright screen without using some power. I only get about 3 hours out of a triple tech battery, and it runs my controller battery down quicker too. I have several small batteries for my controller and consistently change them throughout the day. For commercial use I usually use an S-4 Galaxy tablet when I can’t use an iPad. We fly about 12 hours out of the day…back to back flights.
thank you so much for your suggestion
For flying with DJI GO 4 and Autel Explorer, you’ll want a device with at least 600 to 800 nits of brightness for good outdoor visibility. Popular options include the iPad Mini 6, which has 500 to 600 nits, the iPhone 13/14 Pro, which offers over 1000 nits, and the Samsung Galaxy Tab S8 series, which has around 800 nits. These devices also handle multitasking well and have good battery life. If you fly often in bright sunlight, an iPhone Pro model or a Samsung flagship phone will provide the best mix of performance and screen brightness.
dan333
