Mapping Software
The 2D Orthos...
MapMadeEasy
Lighting 2D zoomed in on Walls, Forms, dirt, tractor as examples
Metashape 2D Ortho Zoomed in on Walls, Forms, dirt, tractor as examples
Lighting 2D Ortho Wide
Metashape 2D Ortho Wide
MapsMadeEasy 2D Ortho Wide
It definately seems Metashape was the most accurate at stitching the photos together (as you can see in the tractor). These are my results on a particular building using Metashape and OpenDroneMapcompare.jpg
Reactions: dougcjohn
It definately seems Metashape was the most accurate at stitching the photos together (as you can see in the tractor). These are my results on a particular building using Metashape and OpenDroneMapView attachment 2624
Similar results, and that's common with several other products.
Good share!
Great comparison between different software dougcjohn!
Metashape results do look really good! I'm still curious since I haven't heard of Lighting software (shame on me) is it also capable to process 3D-mesh? I think you are now comparing two 3D-mesh models and one point cloud (Lighting model).
But still the way Metashape gets sharp edges and vertical planes straight in 3D is impressive. I'm mostly having experience from Pix4D and as you have said there is most of the time no use for 3D-model (mesh) but I do use the 3D point clouds a lot.
RadioTech73
