Possible heat problems with Inspire 2 during 2 hours of flight with multiple batteries changes?
DroneDeploy can tell from the logs what OS was used, but also as already mentioned from how many downloads there have been from Google Play and the App Store. Android is much more fragmented when it comes to versions and builds being used on each type and manufacturer of device. When you allow manufacturers come up with the own build you are just hurting yourself. That said, I use both Android and iOS with DroneDeploy without issue, but I did have to go through a couple of Android devices to find one that was solid. I to have experienced iPad overheating, but that was primarily on the Mini iPads. Packing almost all the same hardware into that much smaller of a form factor can't help. The Mini 4 was ok, but anything before that was severely under powered and would heat up even on cool days. Forget it on any day over 85 degrees.
Ferd Berfel
