Sensor size
Tgleason
Hi all. I wanted some takes on minimum sensor size for 2d to 3d orthos. I read somewhere that a 1" sensor is minimum. But then ive seen others say a parrot anafi 1/2.3" i believe can do it.
My RX1R II only has a 35.90mm x 24.00mm at it does just fine if used properly. The Zenmuse X3 is a 1/2.3" as well and it does a passable job; again, if used correctly.
You can create orthos using a 1/2.3" camera but the results are so much better from a 1" sensor, that it's the de facto standard size for drone mapping.
GerardH143
