Was it or not?
If you really want to have fun and speculate
It was a semi jacketed tracer bullet. Upon impact the jacketing came off and caused the collateral damage and the light seen was the tracer material still burning
We can all speculate and develop as many outlandish theories as our imagination lets us our we can wait to see the outcome of the investigation ? ?
Reactions: PatR
This should help....
(Not my calcs I'm copy/pasting from a post on another forum but these are realistic #'s )
*********** Start Quotation ************
Take an arbitrary helicopter - I'm choosing a Sikorsky UH-60, which has a maximum takeoff weight of 10,000 kg and a rotor diameter of 16.4 m, sweeping an area of 211 m².
To support its weight the downthrust has to be 100,000 N, and so the downward pressure below the rotors needs to be of the order of 500 N/m².
The cross-sectional area of a Phantom is around 0.25 m², and so the downward force on the Phantom would be, at most, 125 N.
Acting on a mass of 2 kg, that will yield a downward acceleration of 62.5 m/s².
The UH-60 flies at 150 knots (78 m/s), and so the time taken for even a stationary Phantom to pass the 16.4 m under the rotors, front to back, would be 0.2 s.
Applying the standard equations of motion, vertically, to the Phantom, it will be deflected downwards by 1.4 m in that time, not even nearly the height of the aircraft.
But, since the fuselage is positioned such that only around one half the length of a rotor blade extends ahead of it, the time that an incoming Phantom would be exposed to the downforce before striking the aircraft would be roughly one quarter of the estimate above - i.e. 0.05 s. In that time the deflection will be around 7 cm. Barely noticeable - it's still hitting the windshield.
*********** End Quotation ************
This is interesting. This calculation is more applicable with the helicopter in a hover. And even with all the downward force of a hover the drone still hits the helicopter.
During acceleration the rotor system acts as a wing and you get translational lift from the wing so the downward force of air is much less. At speed the downdraft is behind the aircraft. There maybe no deflection of a drone at all due to downdraft when the helicopter is At cruise speed.
sanchez_daniel74
