So, have you ever flown your drone and done photography in a warehouse?
I have a customer who wants to have that done possibly in addition to some other work.
I have never flown inside a building and just wanted to know what the risks are and whether it's worth the risks. Is there a minimum height you would want the ceiling to be, and how close would you fly to it?
Have done quite a few indoor flights, mostly arenas.
These are the issues we run into.
Most buildings have a LOT of metal that messes with the compass
---We walk around the interior handheld to identify compass issues preflight.
Some may have large source of magnetic signal from large electric motor ,compressor,etc. ( these may be behind a wall and not in sight of flight area.Also there maybe large frequency emissions in receivers range that can affect the control link
---We use a frequency scanner to identify frequency strength and hz
Most likely to lose GPS and therefore stability.
---We start flight in manual with GPS off as if GPS kickes in and out the AC bounces around. With GPS off you just keep maintaining control over the drifting.
---If you have downward sensors aka VPS(DJI) be careful the floor is clear below flight as benches , boxes , other items rising up from floor will cause the AC to jump up a bit as you fly over.
It does add some stability but if you have the obstructions on the floor I think better to turn it off.
The floor may have heating and/or electrical piping in the floor, also rebar. This might prevent a takeoff from floor.
---Use the travel case or non metal stand to launch.
Make sure there are no people within the flight area.
Watch out for overhanging wires, lighting, fans ( they can put out alot of air which may tumble the AC), banners, loose string etc.
I don't get too close to ceiling normally 6 to 8 feet below but have had to to 1/2 that with no issue.
Your mileage may vary, these are just what we found.
